Author Topic: Boundary Checking problem, leaves either shadow or brighter patch  (Read 5219 times)
DP1633
« on: September 14, 2017, 05:05:51 PM »
I have just set up a new forst pack with the presets, selected boundary checking and whilst it removed the grass along the edge it left a dark patch where the grass should be almost like a shadow.  This is using V-Ray 3.60.02.
I read another topic where someone was having a similar problem and you suggested this would be fixed in V-Ray 3.60.03.  How-ever now the darker area has gone and been replaced with a brighter area.  This happens with Embree turned on and off..
I can't see to get it to render correctly no-matter what I try using V-Ray 3.60.03.  Any suggestions?
JTP Vis
Re: Boundary Checking problem, leaves either shadow or brighter patch
« Reply #1 on: September 14, 2017, 05:22:06 PM »
Have you tried upping the number of levels of transparency allowed in the v-ray render general options?
Bill
EDIT:
see this post:
https://forum.itoosoft.com/forest-pro-(*)/white-pixels-on-forest-grass-with-edge-mode-enabled/msg13164/#msg13164
« Last Edit: September 14, 2017, 05:28:14 PM by JTP Vis »
DP1633
« Reply #2 on: September 14, 2017, 05:31:28 PM »
Yep trying rendering it at 50, 100 and then 1000 and still the same results.
When I rendered it in Vray 3.60.02 with embree turned off it rendered correctly but I though it must work in 3.60.03 so I updated how-ever now I can't find the Vray .02 update to re-install so I can't render it correctly.
Can anyone post a link to Vray 3.60.02 or suggest how to fix in Vray 3.60.03?
« Reply #3 on: September 15, 2017, 01:29:48 PM »
Hi ,
Would you be able to send a simplified scene that reproduces that issue to support@itoosoft.com. I can't reproduce the problem here with V-Ray 3.6.03
Thanks!
DP1633
« Reply #4 on: September 15, 2017, 01:50:46 PM »
I'm just sending you a Max archive through wetransfer of the selected geometry, camera and light.
« Reply #5 on: September 15, 2017, 03:37:00 PM »
Hi Adam,
Thanks for the provided scene. Upon our internal tests, to render it without these artefacts in V-Ray 3.60.02, Embree have to be turned off as advised previously.
In V-Ray 3.60.03 we can't reproduce this problem and it seems to be fixed correctly. I would suggest you to double check your installation of the V-Ray 3.60.03 (mainly the vrender2017.dlr).
Best regards,​​​​
MN4869
« Reply #6 on: November 01, 2017, 08:48:39 AM »
I know someone who was having this same problem - would be interested to hear how you got on.
