Author Topic: Forest Pro Issue  (Read 1135 times)
iToo_Butler
  • Jr. Member
    • DJS CGI
Forest Pro Issue
« on: September 28, 2016, 06:40:10 PM »
Hi all,
I'm having a really annoying, and potentially damaging issue with forest pack.
I'm picking some trees from the iToo Plants 1 library. Namely Bush 6, Bush 7, Flower Bush 1, Linden 3 and Maple 3.
When I render locally they are fine. If I save the file, close it, then go back in, the forest object has lost all it's links again. the reason I noticed is because when i sent it to network render i had no trees. When I then go back in to my file, each of those objects has lost it's link to the tree/bush i chose.
I've rebuilt the forest object many times now and have tried changing the method from xreffing to merging. I still get the same result.
Any idea what might be causing this problem? I'm tearing my hair out over it.
thanks in advance.
iToo_Butler.
Michal Karmazín
  • iToo Software
  • Hero Member
Re: Forest Pro Issue
« Reply #1 on: September 29, 2016, 10:56:32 AM »
Sorry to hear, you're facing those troubles. Would you mind to send us your scene to have a look at it here? Thanks in advance.
iToo_Butler
  • Jr. Member
    • DJS CGI
« Reply #2 on: September 29, 2016, 03:28:17 PM »
Thanks.
An email is on it's way to you!
iToo_Butler.
