Author Topic: Mental Ray crashes when using Forest together Civil View  (Read 1719 times)
iToo
  • Administrator
  • Hero Member
    • Itoo Software
« on: June 25, 2012, 02:59:36 PM »
As soon as i use Forest Pack together Civil View elements, Mental Ray Max crashes, what is the problem ?
In order to render the high-poly trees efficiently, Forest sets up automatically in Mental Ray the following options:
- Renderer->Scanline off
- Renderer->Raytrace acceleration->BSP2
- Processing->Translator options->Use Placeholder Object on
But it seems the Civil View elements are not compatible with "Use Placeholder Object" mode, crashing Mental Ray.
So, if you don't use high-poly trees in your scene (for example using Forest billboards), you can turn off this option. If not, the only way is to exclude the Civil Elements from the render.
« Last Edit: June 11, 2013, 09:15:41 PM by iToo »
Carlos Quintero
Itoo Software
www.itoosoft.com
carlosqg@itoosoft.com
