Author Topic: Creating parametric shelving  (Read 21102 times)
« on: March 13, 2014, 12:39:12 PM »
Post here your questions and comments about the Creating parametric shelving tutorial.
suppenhuhn
Re: Creating parametric shelving
« Reply #1 on: November 05, 2014, 05:45:22 PM »
I'm actually working throug this tutorial..thanks for this good support!
But i'm wondering if it's possible to make the horizontal and vertical shelfboards created by a value(input) i.e. 4xEvenly in X-direction and 2xEvenly in height instead of the input for x/y evenly-distance ? I'm trying to do so but it won't work.
Do you have any idea how to do this?
Thanks in advance.
Robert
« Last Edit: November 05, 2014, 05:48:42 PM by suppenhuhn »
iToo has probably the best support & community i know !!
I'm using it with Max 2019 & Vray 6
« Reply #2 on: November 05, 2014, 05:57:21 PM »
Hi Robert,
Currently the only way to control the spacing of evenly segments is using the Distance parameter. However an alternative "Count" mode in in the works and should be available in the next release.
suppenhuhn
« Reply #3 on: November 05, 2014, 06:15:20 PM »
YEE-HAW!
FQ1241
« Reply #4 on: April 12, 2017, 05:15:58 PM »
Curious if there is any way to have parametric shelves with books or random objects included on them so they don't have to be added separately.
thanks!
Jeremy
« Reply #5 on: April 12, 2017, 05:31:42 PM »
Hi Jeremy,
Sure, there's no reason why you couldn't just combine the techniques shown in the shelving tutorial with those from the books tutorial in a single style. You'd just need to wire together the parameters so that both styles use the same shelf height width values.
FQ1241
« Reply #6 on: June 26, 2017, 07:40:48 PM »
Cool, Ill try. would be great for quick interiors. thanks
