ITOOSOFT Forum
Author Topic: Paving pattern  (Read 10567 times)
HG2581
Paving pattern
« on: April 15, 2014, 11:52:41 am »
Hi
Has anybody got any tips on setting up this type of paving pattern. I just can work out how to get the offset.
  • ITOOSOFT
Re: Paving pattern
« Reply #1 on: April 15, 2014, 02:18:08 pm »
Thanks for your question, I've been able to recreate that style, please see the file attached and the instructions below. In this example the large slabs are 200mm x 200mm and small ones are 100mm x 100mm.
  • Create a new A2S array with an enclosed spline wired to the Clipping area input. From the generator's properties turn on Extend X/Y size to area.
  • Try to identify a repeating pattern, there are many possibilities but in this case I've selected the slabs outlined in red in the following picture.
  • Recreate the pattern using the two paving slab segments and a Compose operator in RailClone. By adjusting the padding and transform values of the segments you can recreate the layout.
  • For each row this pattern offsets by 100mm, we could add a new Transform operators for each offset and wire them to a Y incrementing sequence operator but in this case it will be neater to use an expression. Wire the Compose node to a new Transform operator, Right click the operator and export X Fixed translation
  • Create a new Arithmetic operator, switch the mode to Expression and enter the following: mod(-SegmentYCounter,5)*Input1 The modulo command will keep the number cycling between 0 and 4 as the segment count increases on the Y axis. This is then multiplied by the offset amount that will be wired into the nodes first Input slot. We haven't created this yet.
  • Create a new Constant operator and wire it to the arithmetic node. Change the Constant type to scene units and enter a value of 100mm.
  • Wire the Arithmetic node to the X Fixed Translation input of the Transform node. The final node tree will look like this:
  • This completes the pattern. Because of the offset you will find the right side of the array is ragged. To compensate for this, increase the Generator's General > Clipping Area > Expand percentage. Smaller areas will require a higher percentage.
  • You could also use the Transform operator to introduce some small rotation, translation and scale randomisation.
Please find attached a .max file with the finished style.
Hope that helps,
Kind regards,
« Last Edit: April 15, 2014, 02:20:54 pm by Paul Roberts »
HG2581
Re: Paving pattern
« Reply #2 on: April 15, 2014, 05:17:08 pm »
Thanks! It is easy when you know how, that is just what I am looking for. I could not work out the expression, programming is not my forte.
Fantastic software that just keeps amazing me at what it can do and how easy it makes things!
QM3423
Re: Paving pattern
« Reply #3 on: September 24, 2014, 03:05:05 pm »
This is awesome!  However, i am trying to re-engineer your sample to show a little more variety of stone sizes.  For example, can this be modified to represent a true random-rectangular stone pattern?  T Hat would normally have a variety of squares and rectangles in these standard sizes:   Standard Sizes: 12" x 12", 12" x 18", 12" x 24", 12" x 30", 12" x 36", 18" x 18", 18" x 24", 18" x 30", 18" x 36", 24" x 24", 24" x 30", 24" x 36"
For example, could you help modify your sample scene to include pavers like the attached image (four paver sizes instead of two) and they are a little larger than your sample.  It seems very doable its just a little larger of a repeating area.  But I am over my head here!
Thanks a bunch.
  • ITOOSOFT
Re: Paving pattern
« Reply #4 on: September 24, 2014, 05:45:41 pm »
I've solved that one by creating the pattern first as a separate RailClone object and then nesting this inside another. Because it offsets on both axes I've tried to find a diagonal in the pattern to use as an X axis instead. It's a bit of an odd approach but it works for some patterns. I may be able to find a more elegant solution but this does the job for now :)
Let me know if you have any questions about the file, thanks.
« Last Edit: September 24, 2014, 05:51:29 pm by Paul Roberts »
shiyan lin
Re: Paving pattern
« Reply #5 on: November 03, 2017, 02:34:47 pm »
Hi,Paul
The method you used is quite amazing,I found it very useful,Thanks for sharing!
Below attached a herringbone pattern made with similar method Paul introduced(I know there are herringbone tutorial)
Thanks again for this short tutorial
« Last Edit: November 03, 2017, 03:42:35 pm by shiyan lin »
