Author Topic: RailClone Stadium  (Read 29708 times)
Jose Antonio Dorado
RailClone Stadium
« on: June 26, 2014, 10:06:42 AM »
Post here your questions and comments about the RailClone Stadium tutorial.
Henry
Re: RailClone Stadium
« Reply #1 on: July 09, 2014, 12:19:32 AM »
Link to download tutorial files is not working.
https://www.itoosoft.com/download/rc_stadium_scene_tutorial
« Reply #2 on: July 09, 2014, 02:08:31 AM »
where did you get that link?
offcial link works: https://www.itoosoft.com/download/rc_stadium_scene_tutorial
« Reply #3 on: July 09, 2014, 08:59:37 AM »
We changed the url a couple days after releasing the tutorial, to include the Mental Ray version.
The official link (without zip) works fine. If there is some old link pointing to the zip file, please tell us.
thechrisman
« Reply #4 on: July 17, 2014, 01:32:25 AM »
Hey There,
I'm trying to animate the flags in the Stadium tutorial file with no success. I've animated the flags, then re-linked all the segments, but can't get the animation in the rail clone object. Can you tell me what I'm doing wrong?
Thanks.
« Reply #5 on: July 17, 2014, 09:38:14 AM »
Thanks for contacting us. Animation applied to segments should transfer to the RailClone object with no further steps unless you are animating the translation, rotation, or scale of the object. If you wish to animate transforms, apply an xform modifier and animate the gizmo sub object instead. Animated deformations of the mesh such as bones or cloth should work fine.
I've created a simple file testing these 3 techniques.  You can download it here
I hope this helps, if animation is still not working please let me know.
thechrisman
« Reply #6 on: July 18, 2014, 05:20:00 AM »
Sweet! Thanks Paul!
kadmaster
« Reply #7 on: November 12, 2014, 09:39:11 AM »
Hi, firstly thanks for very useful tutorial.
I have a question about  fourth part of the video.
You put randomize operator for the flags and you put empty segment object to fourth line of the randomize operator. On the other hand, you typed 2000.0 presence value of the randomize operator.
but I can't type 2000.0 in my max. My upper limit is 100,0.So what is my problem? I can not write any value of over 100.
« Reply #8 on: November 12, 2014, 11:27:37 AM »
Yes, you're right. Since the video was recorded we've introduced a maximum limit to those spinners, 100% seemed more logical for a presence parameter. To achieve the same effect you can reduce the percentage value of the flags instead.
I hope that helps.
kadmaster
« Reply #9 on: November 12, 2014, 12:29:19 PM »
Thanks, paul again... I understood the situation... ;D I'm just curious ... I thought that seperator setting was wrong.( "." vs. ",") (2000.0 vs. 2000,0). Thanks for advice and sorry about my english.
Bruno NM
« Reply #10 on: July 17, 2015, 04:17:53 PM »
Hi everyone,
I'm actually on the part 3 of the Stadium tutorial, i got a mistake about the Limit Segment within the Display rollout for scattered chairs.
I set 200 000 in the limit segment section like in the video but Raiclone continue to pop up the message ''Limit has been reach, increase the limit segment parameter''.
I try to increase more, at the maximum, the message still coming.
I test with the Face parameter, set to 50,0 and segment limit set to 200 000 that's work but render are very very long and my computer freeze...
Perhaps i make a mistake before, i don't know why it's doesn't work like the video...
It will be glad if you could help me for this, i would like finish this usefull tutorial  :P
(Sorry for my english)
« Reply #11 on: July 17, 2015, 05:10:03 PM »
Please make sure that Bend and Slice are turned off for the chair segments. This will ensure that these are rendered as instances.
If these are left on, any chair that is deformed by the curved path, or sliced by the end of the spline will be rendered as static geometry which can contribute significantly to render times and create very large polygon counts.
I hope that helps, if not please let me know and if in Doubt, it may be worth opening the finished version of the scene and testing. If that works you can take a look at the settings and see how they differ.
Bruno NM
« Reply #12 on: July 18, 2015, 01:12:01 AM »
Thanks a lot Paul Roberts ! That's work great !
Renders are super fast instead before, 5min 30sec instead more than 1 hour with old parameters for a output size frame 1080p 608p.
Good job !  ;D
Ihno
  • Guest
« Reply #13 on: June 03, 2016, 12:01:01 PM »
Hi, I'm trying to get started with railclone.
And I'm running into a problem in the first part of the stadium tutorial. It appears when I copy the railing with wall and change the spline.
Some parts of the new wall are sliced, see the attached image.
What causes this?
« Last Edit: June 03, 2016, 12:04:59 PM by Ihno »
« Reply #14 on: June 03, 2016, 02:02:48 PM »
HI!
Thanks for contacting us. That's a strange problem and I can't reproduce that here. Could you let me know which version of 3DS Max and RailClone you're using?
