Author Topic: RailClone Pro 2.4.1 beta  (Read 3588 times)
« on: December 11, 2014, 12:12:39 PM »
- Added Style Description. Lets you to see in a quick view, a general description of the style, base objects and parameters.
    * Use Style Editor->Style->Edit description to edit, and Style rollout->Help button to show description.
- Added UVW XForm->Random->Step increment. Lets to define step of random values (e.g. random rotation from 0° to 360° on 90° steps).
- Added more exportable parameters to Segment and Transform nodes.
- Exportable parameters/attributes are sorted by category.
- Added Clear all to Export Parameters/Attributes.
- Generator->Cap Holes feature has been removed, because insolvable texture issues.
- Instancing is not disabled when using features not supported by the engine. These features are just not applied (this was the behaviour of previous versions).
- Added warning message to General->Stats to inform of features not compatible with instancing.
- Fixed UVW XForm->Rotation issues.
- Removed wrong warning when connecting Arithmetic node to Segment->Exported Attributes.
- Nodes with exported attributes are properly collapsed.
- Fixed: Expression editor doesn't display result if node's output is not connected.
- Fixed behaviour of Segment->Flat Top/Bottom when pivot is not aligned to bottom.
- Fixed bug of Compose node when using Segment->Alignment different from Automatic.
- Removed isolated vertices on Generator->Clipping process.
RailClone Pro 2.4.0 beta
- Added UVW XForm operator. (*)
- Added Export Attributes. This feature allows to export numeric values from nodes. e.g. size of a Segment. To use it: select Segment->right click->Export Attributes.
- Segment->Mapping accepts multiple map channels. Write them separated by spaces (*)
- Segment->Mapping, Material and UVW XForm (*) operators can be used with all render engines and RailClone Tools when Display->Use Instancing Engine is off.
- Added Generator->Limits->Padding (Start/End for Linear, Left/Right/Top/Bottom for Arrays).
- Added two modes for Generator->Rules->Evenly: Distance and Count. Distance works as before, and Count creates a fixed number of elements.
- Improved conform to Surface for very large splines. Added parameter to define interpolation's step: Style->Geometry->Surface Interpolation (5cm by default).
- Conditional->Vertex can be used with Default slot. It checks the latest vertex before the Default segment.
- Display->Use Geometry Shader is renamed to Use Instancing Engine.
- Added Generator->Cap Holes. It works same as Cap Holes Max modifier but keeping instancing capability.
- RailClone Tools->Instantiate copies User Properties, Object ID and wireframe color of the source object (when exists).
- Added Segments selector to Quad menu.
  (*) Segments using these features can be instanced only in V-Ray.
Style Editor:
- Improved detection of hotspot for node wiring.
- Style Editor can be placed at left side on multi-monitor configurations.
- Clipboard file (rcclip.dat) is stored in a temporary folder.
- Fix: added creation context menu for wires dragged from Clipping Area slots.
- Auto rename of Parameters and Base Objects on wiring.
- Added result of Arithmetic->Expression on edit dialog.
- Wires can be dragged directly over a node, connecting them to a default slot depending of the wire's type.
- Dragging between nodes outputs swaps their links.
- Fixed: nodes with multiple inputs were keeping empty slots after links deletion.
- All nodes include an On/Off exportable parameter. This parameter is independent of the clickable On/Off state.
- Multiple wiring support, selecting several nodes of the same type and dragging (e.g. to connect multiple Segments to a Randomize operator).
- Added Segment->Right Menu->Clone Multiple. Clones a Segment multiple times, using objects from the scene as source.
- All boolean parameter are available for exporting.
- Randomize->Presence and Sequence->Counter parameters are available for exporting.
- Fixed behaviour of Generator->Align to Path with Corner segments and closed splines.
- Position of panels in Style Editor is saved and restored properly.
- Fixed crash modifying objects assigned to a segment (Max 2010 and older).
- Removed limits from Generator->Fillet Radius.
- Vertex Color channel is generated only when needed.
- A2S Generator->Clipping->Rotation Z now works in local coordinates.
- Segments are updated when their referenced objects are converted to editable mesh.
- Generator->Clipping deletes isolated vertices.
- Fixed rare bug when using no Bend segments at Corners.
- Fixed rare bug with empty segments (see here for details).
- Fixed potential crashing bug moving cursor on viewports while render (V-Ray and Max 2015 only).
- Improved behaviour of Fixed Size with empty Segments.
- Segment->Mapping is aligned correctly when applying random scale.
- Clipping Area is properly updated when Generator is off.
- Fixed bug that would disable Start/End segments when using Base Object->Start/End limits.
« Last Edit: December 11, 2014, 01:00:39 PM by iToo »
