Author Topic: VrayEdgesTex in Bump Channel  (Read 1362 times)
BH4030
« on: October 06, 2015, 03:37:15 PM »
Hello.
Found this topic for RailClone, but it appears that the same goes for Forest Pack too: VrayEdgesTex map in bump slot is ignored by Forest Pack same as RailClone.
Re: VrayEdgesTex in Bump Channel
« Reply #1 on: October 06, 2015, 03:42:58 PM »
As mentioned in the linked thread, unfortunately this is a V-Ray limitation. Vlado has mentioned on their forums:
"[VrayEdgesTex] will not work on proxies for now; this is because when used as a bump map, VRayEdgesTex needs information for the entire mesh - obviously this is not possible with a proxy."
Both RailClone and Forest Pack use the instancing engine used by V-Ray proxies, so these limitations are shared as well.
If a solution becomes available we will certainly add it to our plugins.
BH4030
« Reply #2 on: October 06, 2015, 05:21:50 PM »
Understood. Thank you for quick reply.
