Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
align posts
« previous
next »
Print
Pages: [
1
Author
Topic: align posts (Read 1585 times)
MC4031
Newbie
align posts
on:
November 14, 2016, 04:59:45 PM »
I don't understand why my posts do not align with the staircases
I have to test into vertical but doesn't work
Can you help me?
Thank you
Re: align posts
Reply #1 on:
November 14, 2016, 05:33:29 PM »
The
Deform
Vertical
mode doesn't perform as expected, because your RC object has its local axis rotated as shown on attached screen-shot (specifically the rotation over X axis causes that problem). Setting the rotation to 0º (Z axis is orientated vertically) will fix it (generally it's recommendable to have RC objects aligned to World coordinates system to avoid similar problems). That'll have influence over all Segments / Generators in your style (the
Rotation
of involved Segments should be reset).
MC4031
Newbie
Re: align posts
Reply #2 on:
November 14, 2016, 05:57:15 PM »
oh thanks ! i didnt' see
MC4031
Newbie
Another problem
Reply #3 on:
November 15, 2016, 01:36:42 PM »
I succeeded has to give the adjustments.
But when I put the barriers that does not stick with the posts.
Why?
Re: align posts
Reply #4 on:
November 15, 2016, 01:57:15 PM »
Instead of the
Deform
Stepped
mode, I would suggest you to use the
Vertical
one with defined
Flat Bottom
value (for example 10cm as on attached screen-shot should be fine). Attaching modified scene, hope you'll find it useful.
MC4031
Newbie
Re: align posts
Reply #5 on:
November 15, 2016, 02:00:56 PM »
thank you very much ! And for angles is it normal that it does not stick?
Re: align posts
Reply #6 on:
November 16, 2016, 03:55:02 PM »
Usual approaches to solve these problematic parts are to add a small fillet (
Corner
Fillet Radius
) or modify the Base Object (add a short horizontal part). Hope you'll find it useful.
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
align posts
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
