Author Topic: Forest Pack Lite/Pro 6.2.1  (Read 21661 times)
« on: April 23, 2019, 10:11:51 am »
A new update of the software is available:
Forest Pack 6.2.1
- Added support for V-Ray 3.7.
- Distribution->Reference by Node->Pivot copies the G-Buffer ID of the reference node in Forest Effects->fpItem.userID
   * Note: because a Max limitation, Forest object is not updated when ID changes. You must rebuild manually from Display->Build->Update.
- Fixed crashing bug with Mental Ray.
- Fixed: fpItem.tintMult is casted to integer when modified in Forest Effects.
- Fixed: the process to collect all "maps" folders and add them to Customize->External Files is broken.
- Fixed crash with Paint areas and huge coordinate values (i.e. using millimeters with large surfaces).
