Author Topic: Forest Pack Lite/Pro 6.1.1  (Read 12454 times)
« on: June 22, 2018, 01:10:48 pm »
A new update of the software is available:
Forest Pack 6.1.1
- Fixed bug in Collisions checking.
- Fixed rare bug which causes a continuous updating of the FP object, when using animated splines and the time slider is not zero.
- Fixed crash when applying a UVW Map modifier to the spline in Distribution->Path mode.
- Fixed: multiple selection is lost after changing any parameter in the rollup.
- Fixed: Density->Y Pixels is not greyed out when Lock Aspect ratio is checked.
- Fixed updating issue when switching between Paint Areas and painter is enabled.
Forest Pack 6.1.0
- iToo Toolbars (both Forest and RailClone) can be disabled adding the following registry key:
   HKEY_CURRENT_USER\Software\Itoo Software\DisableToolbars = 1 (DWORD)
- Fixed crash in some machines when plugin is loaded.
« Last Edit: June 26, 2018, 11:02:43 am by iToo »
