		Information (read-only) => Announcements => Topic started by: iToo on March 12, 2021, 01:20:57 pm
				A new update of the software is available:
Forest Pack 7.0.7
- Changed the way that V-Ray proxies are rendered. Now it uses the same method of FP6.
   * Previously render of proxies was delegated to V-Ray, in a similar way to VRayInstancer. But several problems were reported.
   * If needed, VRayInstancer mode can be forced yet in the configuration (forestpack.ini), setting handleVRayProxies = 0.
Library Browser:
- Several fixes for billboard edit:
   * Added missing Center and Z-Offset gizmos.
   * Dimensions are displayed correctly, according to the scene's units.
   * Fixed aspect ratio for non-squared thumbnails.
- Fixed wrong size of billoards loaded from library (not fully fixed in 7.0.6 patch).
- List of Objects/Materials in the import dialogs now are sorted alphabetically.
- Fixed crash deleting catalogs.
Forest Pack 7.0.6
- Fixed several issues loading items from Library Browser.
- Fixed small margins editing Catalog names in the Library Browser.
- Fixed: Scene Explorer is closed before rendering non-geometric objects with some renderers.
   * Note: Scene Explorer is closed yet with Max 2015 and before. This is a workaround to avoid a crash which may happen with old Max versions.
- Distribution->Path / Reference Objects / Particle Flow parameters are not overwritten when loading Library presets.
- Camera->"Limit to Visibility" is updated on viewport only for Camera views.
- Fixed: Billboards are loaded with a wrong size from the Library Browser.
- Library Browser is reloaded when Unit's scene change. This is needed to show correctly the billboard units.
This is a maintenance patch only. You can find all new features of Forest Pack 7 here (https://forum.itoosoft.com/announcements/forest-pack-7-is-out-now-see-the-light!/).
If you have any questions about this release, please let us know on the forums (http://forum.itoosoft.com/index.php?board=5.0).
