Author Topic: RailClone Lite/Pro 5.0.9  (Read 14777 times)
« on: January 11, 2022, 12:17:49 pm »
A new update of the software is available:
RailClone 5.0.9
- Added new 'Free' option to 'A2S Generator->Clipping Area->For No-Slice'.
   * It keeps the segment always, regardless if is inside, sliced, or outside of the clipping area.
   * Instead, 'Preserve' option keeps the segment only when is inside or sliced, and removed when outside.
- Added more control to Segment->Mapping: Offset and Rotation in XYZ.
- Fixed: Bevel no consistent across rows when using arrays with vertical Y Spline.
- Fixed: Animated objects only renders first frame in Arnold.
- Fixed: Export Parameter/Attribute is not properly recorded in Undo/Redo.
- Fixed: Banking position is not correct when using spline Filter by ID or Padding.
- Disabled Banking for Array Generators using 'Free' mode. This combination is not compatible.
- Fixed: Nested arrays using clipping area may not generate geometry, depending of the spline position.
RailClone 5.0.8
- Fixed crash using A2S->"Extend to Size" with multiple sub-splines (bug introduced in RC 507).
- Fixed DLL error in Windows 7 (bug introduced in RC 507).
RailClone 5.0.7
- Fixed dissapearing Spline sections using material IDs greater than 64.
- Fixed crashing error rendering nested RailClone objects.
- Fixed: Generator->Limits->Padding not working with Limits by Material ID.
- Fixed: XSectionNumber returns 1 when Generator->Limits by Material ID used.
- Fixed: Lights with XForm applied are not supported.
- Fixed crash deleting RC Spline modifier is Banking Create button is enabled.
- Fixed: 'DotProd' function is not recognized in Expressions.
- Fixed alignment issue on nested generators when segment is planar (some dimension is zero).
- Improved performance of nested generators (fixed a redundant re-evaluation of inner generator).
- Fixed column width of list boxes (Base Objects, Parameters, etc) on HiDPI screens.
Note: if you get a DLL error loading railclonepro.dlo in 3DS Max, please install the latest Visual Studio redistributable from this link.
RailClone 5.x is a major version with multiple changes and improvements. To see the full list of features, check out the announcement on our blog.
