Author Topic: RailClone Lite/Pro 6.1.5  (Read 39292 times)
« on: January 02, 2024, 09:34:53 am »
A new update of the software is available:
RailClone 6.1.5
- Fixed: Limits->Material ID not working in the Extend X/Y Size to Area mode.
- Splines are trimmed by 'Base Objects'->'Full Length' only if Start/End parameters have an applicable range.
   * This fixes an issue where closed splines are considered as opened, when 'Full Length' is unchecked but Start/End parameters have default values.
- Fixed: Generator->'Flatten Stepped' has not any effect.
   * Also added performance improvement when applied on flat splines.
- Fixed: Mirror Operator breaks Segment UV mapping on nested generators.
