Author Topic: RailClone Lite/Pro 1.3.0  (Read 16522 times)
« on: December 28, 2011, 07:34:24 pm »
  • RailClone Tools. This utility converts the RailClone geometry to standalone objects, creating automatically meshes and instances where needed. You can use it to create instanced geometry in render engines which are natively supported by the plugin, or to export the scene.
  • New parameter: Display->Disable Object. It disables completely the RailClone object, both in viewport and render.
  • Fixed geometric glitches when using the VRay/Mental shader.
Note: RailClone Tools is available only in RailClone Pro.
