Author Topic: Forest Pack Lite/Pro 4.0.2  (Read 17655 times)
« on: March 11, 2013, 05:50:56 pm »
  • Fixed bug that would, in some cases, create continuous updating loops in Max.
  • The Presets texture path is added to the Max configuration. Now Forest adds atomatically all paths listed in the following registry key:
      HKEY_LOCAL_MACHINE\SOFTWARE\Itoo Software\Forest Pack Pro\TexturePaths.
  • 3D Models are properly loaded from the library in "Merge" mode, not as XRef.
  • Added compatibility for Maxwell plugin 2.7.24. Note: This is now the lower version supported.
  • Maxwell render visibility flags are used.
  • ForestLite / ForestPro macros are available in Customize->Customize User Interface (for toolbars and others).
  • Fixed materials of Wild Grass Presets.
  • Fixed crash when the distribution map cannot be loaded.
  • Material->Fast Opacity is put back for compatibility with previous scenes (removed in 4.0.1).
Registered users of Forest Pack Pro can download the upgrade from the User Panel. The Lite version is freely available to download in our website.
