Author Topic: RailClone Pro 2.2.0 beta  (Read 12648 times)
« on: December 21, 2013, 12:45:13 pm »
Note: Beta versions include new features and fixes, but a beta version is NOT the final version of the product and therefore we not guarantee an absence of errors that may disrupt the computer's operation and/or result in data loss. Use it always at your own risk.
Registered users of RailClone Pro can download the upgrade from the User Panel->Beta versions.
New features and changes:
- New Parameter node: Random number.
- Added General->Stats information window.
- Added Segment->UV Mapping->Rotation.
- New Default mode: Count, allows to define a fixed number of segments.
- Linear 1S Generator can be built without a spline, setting X Size parameter.
- Added Style->Geometry->Free Object. When enabled, RailClone doesn't use the spline's position, only its shape.
    Use it to move RC freely along the scene (without the spline), or to create instanced objects.
- Added up/down arrows to Base Objects/Parameters lists.
Fixes:
- Fixed error that would generate misaligned segments on render.
- Fixed error using geometric shader and mirrored segments.
- Constant parameters are affected by Geometry->Global scale.
- Fixed: Compose operator works properly with Default->Scale mode.
- Fixed: Material Sequence operator was adding +1 to the ID value.
- Fixed: Segment->Flat Top/Bottom controls are disabled if Bend is off.
- Fixed alignment of initial segment when using Vertical or Stepped mode.
- Fixed: some arithmetic expressions are evaluated as integer values.
- Fixed Randomize operator with nested RC objects.
- Fixed Region Clipping using nested splines on specific viewport aligments.
