Author Topic: Forest Pack Lite/Pro 5.3.2  (Read 12829 times)
« on: April 20, 2017, 03:36:53 pm »
Forest Pack Pro and Lite 5.3 is now available. This update adds support for V-Ray 3.5 including IPR rendering and Forest Color compatibity with V-Ray RT GPU in addition to several important fixes and improvements.
Please see the release notes below for details.
Forest Pack 5.3.2
  • Point-cloud using color ID is gamma corrected.
  • Fixed problems with Forest Tools (broken in v5.3.0).
  • Removed dependencies from V-Ray in some library scenes.
Forest Pack 5.3.1
  • Fixed rendering of billboards in V-Ray.
  • Fixed crash rendering with Redshift.
  • Fixed crash with Forest Color and Corona interactive.
Forest Pack 5.3.0
  • Added support for V-Ray 3.5.
  • Added support for V-Ray 3.5 IPR mode. Several limitations are known:
    • Forest object is not visible in viewport while IPR is running (this will require major changes in the code and is postponed for a major release).
    • Camera clipping is not updated dynamically. To update it, click Display->Build or Build All.
  • Added Forest Color support for V-Ray RT GPU (in collaboration with Chaos Group). Please see the video below for a demo of this new V-Ray 3.5 feature.
  • Library->Filter checks if text exists in any part of the item's name, not only at the start.
  • Forest Lister: Added range selection clicking with Shift, and Select All/None buttons.
  • Fixed crash with missing VRayProxy assets.
  • Fixed crash rendering multiple frames in Corona Renderer, when using Custom Edit mode and camera clipping.
  • Fixed random issues with Editable Meshes in Max 2017, when used as Surfaces or objects.
  • Fixed geometry issues with VRay proxies using "Flip Axis".
  • Fixed empty entries in "Customize User Interface".
