Author Topic: RailClone Pro 6.0.0 beta  (Read 21401 times)
« on: February 15, 2023, 11:21:23 am »
Note 1: Beta versions include new features and fixes, but a beta version is NOT the final version of the product and therefore we don't guarantee there won't be errors that may disrupt the computer's operation and/or result in data loss. Always use it at your own risk.
RailClone 6.0.0 beta
- Improved Library Browser. It has been rewritten from the ground up to make it easier to develop new features in the future. This initial release adds the following improvements:
   * Library Items are created from scene selection.
   * Material Library and Max scene is generated automatically.
   * Assets can be collected to a maps folder.
   * Improved search that filters matching items across all libraries.
- New modifier: RCSlice
   * Slices a mesh in all pieces used by RailClone, both for linear and array generators: Start,End,Default,X Evenly,X Corner,Top,Bottom,Start Top,End Top,Start Bottom and End Bottom.
   * Modifier output can be selected to any of these pieces, the full geometry or a mesh with all slices.
   * 'Segment' node includes a new parameter (RC Slice), to get automatically any piece of the object, when this uses a RCSlice modifier.
   * When used together 'Segment->RCSlice' parameter, place always RCSlice on top of the stack modifier.
- Added support for rotated or scaled items in groups.
- Added support of RailClone Color in Corona Renderer (v9 or above) using instancing.
- Segment->Deform->Flat Top/Bottom allows negative values.
   * To keep compatibility with existing scenes, Flat Top/Bottom is not applied when value is exactly zero.
- Fixed: toolbar is not restored to its last position, when Max is loaded.
- Fixed: toolbar's RailClone creation doesn't work in Lite version.
- Fixed wrong segments generated in FStorm when using Interactive Render.
- Fixed: Segments are placed below the spline when using Stepped with Bevel->Extend mode.
- Fixed: when 'Extract Segments' is applied two or more times, materials are lost.
- Fixed rare crash in V-Ray with VRayMultiTexmap.
- Fixed: lights using RailClone Color generates a wrong colour. It was correct in RC 5.2.6.
Style Editor:
- We changed significatively the behaviour of Style Editor:
   * In previous versions, Editor was closed when RailClone object was deselected.
   * Now you can continue editing the Style, even if RailClone object is not selected.
   * To edit a different object, you must click 'Open Editor' button on the new object.
   * Some actions close Editor automatically, as Open Library, enable Style Linking and others (this was not changed).
- New node: Link.
   * It just connects the input with the output. Use it to organize wiring in complex styles.
   * Type of node must be selected in properties: Segment, Spline, Surface or Numeric.
   * Node Style can be Normal or Simplified.
   * Wire Style with other Link nodes can be Normal, Dashed or Hidden.
- Added Reroute nodes. It lets you to modify a wire, adding intermediate nodes.
   * Add them with double click over a wire.
   * Reroute nodes has a single input and output. To derive multiple outputs from a wire, use a Link node instead.
- Added clone operations using 'Shift' key:
   * Moving selected nodes while clicking Shift, clone them.
   * Clicking a wire output, clone it.
- Styles can be protected by a password, which is requested for editing.
   * Set or remove the password at Style menu ->'Protect by Password'.
   * Be care, there is no way to recover the password if you forget it.
- Added new Arithmetic attributes:
   * 'InRender': returns 1 when building for render, 0 for viewport.
   * 'XSplineClosed', 'YSplineClosed': returns 1 when spline is closed, 0 if open.
- Added 'Import 3DS selection' to right menu.
   * Imports 3DS selected objects to the Editor as Segment or Spline nodes.
- Macro parameters can be grouped in categories.
   * Use main menu->Macro->'Define Parameters Order' dialog to edit categories.
- Numeric parameters can be disabled. Also On/Off state is exportable.
   * When disabled, they behaviour as non-connected.
- Added Seed options to Randomize node.
   * It provides same features as Random numeric node, as 'Sync between Generators', 'Generate on', etc.
- 'Align Mode' can be exported as a numeric parameter, both from Segment and Transform nodes.
   * 0: Automatic, 1: Pivot, 2: Min, 3: Middle, 4: Max.
- Added View->"Hide Wires" option (Ctrl-W).
   * When enabled, only wires of selected nodes are visible.
- Fixed: Colour of Input/Output Macro nodes is not initialized correctly.
- Added options to select wire thickness (Preferences->Wires->Thin width).
- Link->'Insert Node' contextual menu was not working well and is removed. Use Drag & Drop over link instead.
- Added option to assign object to multiple Segment nodes (select Segments->Property->Assign Object).
- Copying and pasting a Segment/Spline/Surface to a macro doesn't generate an error anymore. Instead, node is converted to a Macro Input node of the appropriate type.
- Double click over a Macro node opens it for editing.
- Added 'Reset Parameters' option to Macro's contextual menu. It resets all parameters to their default values.
- Added Selection mode at toolbar: Window/Crossing.
- Added load/save options to drop down list parameters (Selector).
- Added AND/OR mode to Conditional operator.
- Added Combo Selector as new parameter type for macros.
Registered users can download the upgrade from the User Panel->Beta versions. For any question about this release, please use the RailClone beta forum.
