Author Topic: Forest Pack Lite/Pro 8.2.1  (Read 27213 times)
« on: May 02, 2023, 09:03:29 am »
A new update of the software is available:
Forest Pack 8.2.1
- Changed the way that Forest handles the texture paths:
   - In previous versions, all libraries defined in the Library Browswer was scanned, searching for 'maps' folders. Next, these folders are added to 3DS Max in Customize->'Configure Project Paths'->'External Files'.
   - Now, only the builtin library ('Forest Library') is scanned. You can extend it to all libraries unchecking Library Browser->Preferences->'Only BuiltIn Library'.
   - Forest repeats the scanning process when plugin is loaded. Besides that, a button is added to Library Browser->Preferences to launch the process manually.
- Fixed: Forest Material renders completely black in V-Ray (broken in FP 8.2.0).
- Fixed: Forest quad menu is not available unless initialization script (forestpack.ms) is executed manually.
- Fixed: Color Management profile is reset to "unmanaged" in Max 2024, when using Forest.
- Fixed memory leak in Max 2023 and before using Display->Mesh mode.
- Fixed: Distribution by Particle Flow generates duplicated items.
