Author Topic: RailClone Lite/Pro 6.1.6  (Read 39415 times)
« on: February 01, 2024, 10:31:44 am »
A new update of the software is available:
RailClone 6.1.6
- Fixed error rendering with Redshift (it would affect to other render engines as well).
- Fixed: in some cases nested RailClone don't generate any geometry.
- Fixed: changes on scene objects (as modifying pivot) which are assigned to multiple segments, are reflected only in one of them.
- Fixed: Modifying the Pivot Point of a RCSlice doesn't affect all slices.
   * On existing scenes, it may be required to reassign the RCSlice object to each Segment.
- Fixed: Selector Operator doesn't select the corresponding Segment based on the Y Spline Marker ID value.
- Improved performance of Library Browser, when loading multiple items using same material library.
- Several improvements to the process of loading and resizing thumbnails in the Library Browser.
