Information (read-only) => Announcements => Topic started by: iToo on October 15, 2024, 12:31:31 pm
A new update of the software is available:
Forest Pack 9.1.3
- Fixed viewport lag using nested Forest objects.
- Distribution->Image->'Map Channel' is limited to values greater than zero.
* Also Map Channel parameter is enabled only for UV Surface mode, since it has not effect in XY mode.
ForestIvy:
- Fixed excessive RAM usage in render nodes when using Quick-Mesh viewport mode.
Forest Pack 9.1.2
- Fixed crash with Point-cloud and Camera clipping.
- Fixes issues with nested Forest objects using Custom Edit mode.
- Fixed: Some pop-up warning windows may interrupt the non-interactive rendering process. Now they are sent to the log system.
- Added Minimize/Maximize buttons to Library Browser.
- Fixed missing icon for Filter->Options in Library Browser.
ForestIvy:
- Fixed artifacts when ivy growths below the ground plane (as defined by the local XY plane).
- Added Growth->'Check Ground Hit'. When enabled, ForestIvy checks collisions with the ground plane.
- Added Growth->'Surface Offset'. Used to separate ivy from surface.
- Fixed material error loading library presets in Arnold, with Max 2021 and before.
- Fixed issues when growing over regular geometries.
If you have any questions about this release, please let us know on the forums (https://forum.itoosoft.com/forest-pro-(*)/).
