Author Topic: Forest Pack Lite/Pro 9.1.4  (Read 32987 times)
« on: November 07, 2024, 01:38:38 pm »
A new update of the software is available:
Forest Pack 9.1.4
- Added support for V-Ray 7.
- Fixed: items are rendered as proxies when using Forest Areas in IPR mode.
- Fixed crash creating Forest object when IPR is running.
   * Although crash is fixed, we encourage to not create FP objects while rendering with IPR. It may cause unexpected behaviours.
Forest Pack 9.1.3
- Fixed viewport lag using nested Forest objects.
- Distribution->Image->'Map Channel' is limited to values greater than zero.
   * Also Map Channel parameter is enabled only for UV Surface mode, since it has not effect in XY mode.
ForestIvy:
- Fixed excessive RAM usage in render nodes when using Quick-Mesh viewport mode.
Forest Pack 9.1.2
- Fixed crash with Point-cloud and Camera clipping.
- Fixes issues with nested Forest objects using Custom Edit mode.
- Fixed: Some pop-up warning windows may interrupt the non-interactive rendering process. Now they are sent to the log system.
- Added Minimize/Maximize buttons to Library Browser.
- Fixed missing icon for Filter->Options in Library Browser.
ForestIvy:
- Fixed artifacts when ivy growths below the ground plane (as defined by the local XY plane).
- Added Growth->'Check Ground Hit'. When enabled, ForestIvy checks collisions with the ground plane.
- Added Growth->'Surface Offset'. Used to separate ivy from surface.
- Fixed material error loading library presets in Arnold, with Max 2021 and before.
- Fixed issues when growing over regular geometries.
