Author Topic: RailClone Lite/Pro 6.3.8  (Read 47414 times)
« on: January 03, 2025, 01:28:30 pm »
A new update of the software is available:
RailClone 6.3.8
- Fixed rare freeze issue applying slice operations.
- Fixed: Slice operation adds additional vertices to corner meshes.
RailClone 6.3.7
- Fixed: Delete key stop working with certain operations of Forest/RailClone Lister (new fix).
- V-Ray proxies don't require anymore to set full mesh mode to be rendered in V-Ray GPU and Vantage.
RailClone 6.3.6
- Fixed crash using Macros library (bug introduced in RC 6.3.4).
- Fixed rare case which caused a 3DS Max freeze when building geometry.
RailClone 6.3.4
- Delete key stop working after closing Forest/RailClone Lister.
RailClone 6.3.3
- Added support for V-Ray 7.
- Fixed: Macro->Numeric node is missing default and limit values for integer type.
RailClone 6.3.2
- Fixed: Node properties may appear as an extra floating window.
- Fixed 'Style Error' using nodes with non-latin characters.
- Fixed locking issue using Shift-Tab in Transform node.
- Fixed rare crash selecting nodes in Sytle Editor.
- Fixed description for 'XVertexType' expression attribute.
RailClone 6.3.1
- Fixed random crash removing nodes in Style Editor.
- Fixed duplicated entries in contextual creation menu.
