Author Topic: Forest Pack Lite/Pro 9.2.3  (Read 75072 times)
« on: May 21, 2025, 10:45:06 am »
A new update of the software is available:
Forest Pack 9.2.3
- Fixed: Filter by Mat.ID doesn't work well with Surface UV mode.
- Fixed visible triangulation edges in V-Ray scenes using large bounds.
   * This fix also requires RailClone is updated to 6.4.3 or greater.
- Added icon text to ForestSet.
- Adjusted position of icon text to bottom.
Forest Pack 9.2.2
- Fixed accumulative performance issue in large Forest objects, when rendering interactively multiple times.
- Fixed: items added in Custom Edit mode are not randomized.
- Fixed: Items Editor->Add with ForestSet adds all items of the set.
- Fixed crash selecting Reference objects in 3DS Max 2026.
- Fixed crash selecting ForestIvy->Surfaces by name in 3DS Max 2026.
- Fixed: high values in Statistics are displayed as negative numbers.
Forest Pack 9.2.1
- Added support for Arnold 7.4.
- Fixed: Z Offset is doubled when switching to Custom Edit mode.
- Fixed ForestIvy issue when using rotated surfaces.
Forest Pack 9.2.0
- Added support for 3DS Max 2026.
- Added Display->'Show FP Icon'->'Icon Name', to show the Forest object name.
- Added Icon options to ForestIvy.
- ForestLOD items with same Distance/Size are distributed randomly. Previously only the first matching item was used.
- Added support of ForestSet in ForestLOD.
« Last Edit: May 21, 2025, 10:49:55 am by iToo »
