Author Topic: RailClone Lite/Pro 7.1.3  (Read 17637 times)
« on: September 25, 2025, 12:33:43 pm »
A new version of the software is available:
RailClone 7.1.3
- Fixed wrong texture mapping in presets loaded from the Library.
  * Besides installing the update, to fix the mapping issue you must reload the style from Library.
RailClone 7.1.2
- Fixed scale issue for 'Windows' libraries when working with scenes using centimeters.
- The Offset operator now respects the spline's local coordinate system instead of using the RailClone coordinates. This approach is much more suitable for rotated paths.
- Improved edge detection when the boundaries of Surface and Spline Areas are coincident.
- Fixed: Flatten Stepped doesn't work if using an empty Transform node in place of geometry.
- Fixed: Spline->Transform->Rotation causes a spline flip when rotating exactly 180 degrees.
- Fixed: Value List cannot use negative values.
- New library content: iron and wooden balustrades under Architecture > Exterior.
RailClone 7.1.1
- Fixed: Library Items using Portable format are not scaled with scene's units.
- Fixed: RCSlice parameters are not scaled with scene's units.
- Fixed material error loading 'Windows' libraries.
RailClone 7.1.0
- Fixed issue of Material operator in Arnold renderer when instancing is enabled.
- Fixed issues with Portable Material libraries.
- Updated 'Windows' library.
RailClone 7.0.9
- Added support of V-Ray 6 in 3DS Max 2026.
- Fixed freeze issue with Segments using modifiers.
- Fixed: items are not properly instanced when using Mirror operator.
- Fixed geometry displacement with some segments using RC Slice.
- Fixed: RC Slice->'Y Default' doesn't work well if 'X Default' is disabled.
- Context menu->Selector dialogs are larger and resizeable.
