Author Topic: RailClone Pro 1.1.3 beta  (Read 27796 times)
« on: April 24, 2011, 09:37:29 pm »
Note 1: Beta versions include new features and fixes, but a beta version is NOT the final version of the product and therefore we not guarantee an absence of errors that may disrupt the computer's operation and/or result in data loss. Use it always at your own risk.
Note 2: The following files are included on this release to provide VRay and Mental Ray support: RailCloneVRay150sp3.dll, RailCloneVRay20.dll in the Max root folder, and RCShader.mi, RCShader.dll in <maxdir>\mentalimages\shaders_autoload\mentalray. All files are installed by the setup program.
RailClone Pro 1.1.3b
- Added geometric shader for Mental Ray:
    * It works similar to the VRay shader, allowing you to render massive railings and structures
    * Objects are converted on the fly to native render instances
    * mrProxies are supported
Note: The shader is not compatible with Randomness->Material ID, Mapping and Vertex welding. You can revert to the standard mode turning off 'Display->VRay/Mental shader' parameter.
- Fixed error in VRay when a same object was used in several segments with different transformations
RailClone Pro 1.1.2b
- Added Max 2012 support
VRay:
- Improved performance and reduced memory footprint for very large objects. The geometry is generated dynamically inside the camera frustrum, allowing you to render complex objects over splines as long as kilometers
- The use of render instances has been optimized, using them in Corners and Evenly positions over straight segment paths
- Proxy file search now works properly on network render
- Proxies are aligned correctly when using Geometry->Flip
RailClone Pro 1.1.0b
New features:
- CPU Multi-core support. Global performance have been improved
- Proxies and high-poly meshes support for VRay:
    * Lets you to render huge number of high-poly objects using minimal resource
    * Proxies and objects are converted on the fly to native render instances
- Mapping Coordinates (Randomness rollout)
   * Avoid texture tiling, applying box mapping to the Segments along the path
- New "Display" rollout:
    * Configurable "Boxes" mode for Viewport and Render
    * Adaptative mode. Use "Boxes" mode on viewport if the number of faces specified is exceeded
    * "Boxes" display mode is more accurate respect to the full geometry
    * Render mode: Automatic mode uses native instances for VRay or Mental Ray. Meshes mode creates a unique mesh for the geometry
    * Build button and Max.Faces and Max.Segments parameters have been moved from the General rollout here
Fixes:
- Fixed geometric issues when applying both random rotation and scale
- Bevel works properly on splines with collinear vertices
- Geometry->Copy From/To works properly on RailClone objects with modifiers
- Fixed minor Library Browser issues
RailClone Pro registered users can download the software from the User Panel (My Betas section).
Sample scene using huge RailClone geometry with VRay
