Author Topic: Forest Pack Pro 5.0.8 beta  (Read 12794 times)
« on: June 30, 2016, 12:52:23 pm »
Note: Beta versions include new features and fixes, but a beta version is NOT the final version of the product and therefore we don't guarantee there won't be errors that may disrupt the computer's operation and/or result in data loss. Use it always at your own risk.
Registered users of Forest Pack Pro can download the upgrade from the User Panel->Beta versions. For any question about this release, please use the Forest Pack beta forum.
Forest Pro 5.0.8 beta
- Fixed invisible objects in V-ray when using VRayPhysicalCamera with motion blur or PhysicalCamera.
- Fixed: Effects->Distance to area attributes don't return correct values at least that Area->Fallof is enabled.
- Fixed bug with Animation modes in Mental Ray.
- Fixed rare crash bug when using Animation modes and Display limits.
- Forest Lister is sorted by object's name.
Forest Pro 5.0.7 beta
- Added support for Max 2017.
- Added option to customize Font Size for the Lister (see Options).
- Actions of the Toolbar are available at "Customize User Interface" (within "Forest Pack" category).
- Fixed crash when rendering without license.
- Fixed: Effects->dotprod function was decleared as vector instead real.
- Fixed: Toolbar placed out of screen and not visible (see Note 1).
- Fixed: Toolbar is not available after a Workspace change.
- Fixed: Effects->random generator doesn't return consistent values in Custom Edit mode.
- Fixed rare bug that would cause animated objects are not updated correctly.
- Fixed: in some cases Forest Exclude Areas has no effect after the first animation frame.
- Fixed: Forest doesn't update with changes of rotation or scale on Custom Objects, until scene is reloaded.
- Fixed bug with XRef scenes binded to a rotated object.
- Fixed updating issue with Effects using "max.time" property.
- All configuration keys defined at HKEY_LOCAL_MACHINE can be read alternatively from same branch at HKEY_CURRENT_USER.
   This feature lets you to create custom installations using non-administrative accounts.
Note 1: if toolbar is not visible even after this update, try removing the following file and restarting Max:
   C:\Users\<your user name>\AppData\Local\Autodesk\3dsmax\<your max version>\ENU\en-US\plugcfg\forestpack_toolbar.ini
« Last Edit: June 30, 2016, 01:41:18 pm by iToo »
