Author Topic: RailClone Lite/Pro 3.1.0  (Read 12583 times)
« on: January 31, 2018, 10:48:15 am »
A new version of RailClone Lite and Pro is available.
RailClone 3.1.0
- Added support for V-Ray Next beta 1 (experimental).
- Added "Force Instances" to RailClone Tools.
    * When enabled, the Instantiate tool generates as many instances as possible, ignoring Material and UVW operators.
    * This option mimics the behaviour of RC Tools previous to v3.0.9.
- Arrays generated from clipping areas use Mat.ID of spline for Selector, Conditional and Expressions nodes.
    * Note: ID is taken from the first spline's segment.
- Improved text visibility of "Note" nodes, according to the background color.
- Fixed: objects created with RC2 are not upgraded to RC3 when using XRef scenes.
    * This problem occurs in the main scene, not in the XRef'd one.
    * Once saved with RC3, failed objects cannot be fixed even loading them with this patch. To help with that, we added a Maxscript function to fix them manually. Just select one by one, and run: $.upgradeFromVersion(275)
- Fixed bug with Clipping Areas when using Generator->Z Offset.
- Fixed: "easeOut" function was wrongly named as "easeOn".
    * Please note that if you was using "easeOn" in your expressions, these must be changed manually.
- Description of easing functions (easeIn, easeOut, easeInOut) is rewritten to a more descriptive text.
- Fixed crash with V-Ray IPR.
- Fixed: RailClone Tools doesn't apply material and UVW transformations when "Separated Meshes" is enabled.
- Fixed: User toolbars using RailClone actions are reset when Max is loaded.
- Fixed bug with Bevel Corners in A2S generators using a vertical Y spline.
You can find the release notes for previous RailClone versions here.
