Author Topic: Forest Pack Pro 9.0.7 beta  (Read 48277 times)
« on: July 19, 2024, 10:47:46 am »
Note 1: Beta versions include new features and fixes, but a beta version is NOT the final version of the product and therefore we don't guarantee there won't be errors that may disrupt the computer's operation and/or result in data loss. Always use it at your own risk.
Note 2: If you use RailClone Pro beta, please be sure to install the latest update as well. Forest and RailClone share several library files, which must be in the same version.
Note 3: While the beta, we may introduce changes that modify randomization of ForestIvy, in scenes created with previous builds. Once the software is released as stable, this should not happen anymore.
- Fixed: Stack of surfaces uses only topmost layer in Size mode.
ForestIvy
- Fixed: 'Death.Distance Max' is set to 'Distance Min' when loading the scene.
- Fixed exporting issue to portable format (.fp) when scene uses other units than cm.
Forest Pack Pro 9.0.6
- Added button to open License Manager from General rollup.
- Improved license dialogs, including link to documentation and button to open License Manager.
- Forest Tools->Instantiate creates items in the layer of the Forest source object.
- Fixed: Point-cloud mode draws items when FP object is disabled in Custom Edit mode.
ForestIvy
- Growth->Collision Check->Precise is removed.
- Changed behaviour of Display->Limits->Branches, so it doesn't depend of number of Segments by Branch, as before.
Forest Pack Pro 9.0.5
- Fixed error loading ForestIvy presets from library.
  * Also please be sure to run Update Manager, to download the latest 'Climbing Plants' package.
Forest Pack Pro 9.0.4
ForestIvy
- Added Display->'Leaves Density'.
- Improved visibility of branches in Point-cloud mode.
- Fixed: Viewport and render models are not synchronized when rendering with V-Ray IPR.
- Fixed issues when surface is placed below ForestIvy Z position.
Forest Pack Pro 9.0.3
- Fixed missing clicks on Forest Lister buttons.
- Fixed delay handling Forest object on non frame zero.
- Fixed: double clicking over an library/folder in Library Browser selects a wrong item.
ForestIvy
- Added Leaves->Density Falloff (Distance / Strength)
   * 'Distance' defines the distance limit along the branch to apply it.
- Added separated Align mode for End Leaves.
- Improved behaviour of Leaves->'Align Ground'.
- 'Death distance' is applied only to hanging branches.
- Fixed crash loading from Library Browser if portable file (.fp) doesn't exist.
- Fixed: End Leaf always is same model.
- Fixed: grow without baseline has issues when not at Z=0 position.
- Fixed: branch is not properly updated when rendering with V-Ray IPR.
- Fixed: Different Death Distance min and max values has bog changes on distribution.
Forest Pack Pro 9.0.2
- Fixed crashing bug in V-Ray related with UVW channels. (FP9 bug)
- Fixed Tooltips / toolbar buttons mismatch.
- Increased default number of points for hit-testing in Point-cloud mode to 10000 (forestpack.ini: cloudHitTestMaxPoints).
   * Note: if you have used any FP9 version before this update, you must update manually the value of 'cloudHitTestMaxPoints' in forestpack.ini.
- Optimized 'ForestEdge' for objects not using Edge mode (15% improvement).
- Fixed width of some columns in Forest Lister.
- Fixed: ForestColor applies tint to non-Forest objects when not using 'Override'.
Forest Ivy
- Added support of Forest Color->Tint from Surface map.
- Improved support for animated leaves (using animated models or changing leaves parameters).
Forest Pack Pro 9.0.1
- Fixed crash when MaxToA package (Arnold) is not installed.
- Fixed 'division by zero' crash when rendering on Surface UV mode.
- Fixed: V-Ray proxies are not properly displayed on viewport.
- Improved Point-cloud behaviour using low density values, on objects with many small items (as ForestIyv).
- Fixed several bugs related with UV Surfaces and map channels.
- Enabled limit by material ID for UV surfaces.
- Added tooltips to the toolbar buttons.
- Fixed: the installer incorrectly displays '3DS Max 20240' instead of '3DS Max 2025'.
Forest Ivy
- Growth->'Death Distance' is changed from a fixed value to a random range (min/max).
- Fixed license error in render nodes.
- Fixed: several parameters are initialized with a wrong default value.
This is an update of Forest Pack 9 beta, which includes major changes and improvements. You can get all details about this release in this post.
