Author Topic: RailClone Lite/Pro 5.0.7  (Read 14058 times)
« on: December 28, 2021, 09:10:07 am »
A new update of the software is available:
RailClone 5.0.7
- Fixed dissapearing Spline sections using material IDs greater than 64.
- Fixed crashing error rendering nested RailClone objects.
- Fixed: Generator->Limits->Padding not working with Limits by Material ID.
- Fixed: XSectionNumber returns 1 when Generator->Limits by Material ID used.
- Fixed: Lights with XForm applied are not supported.
- Fixed crash deleting RC Spline modifier is Banking Create button is enabled.
- Fixed: 'DotProd' function is not recognized in Expressions.
- Fixed alignment issue on nested generators when segment is planar (some dimension is zero).
- Improved performance of nested generators (fixed a redundant re-evaluation of inner generator).
- Fixed column width of list boxes (Base Objects, Parameters, etc) on HiDPI screens.
Note: if you get a DLL error loading railclonepro.dlo in 3DS Max, please install the latest Visual Studio redistributable from this link.
RailClone 5.x is a major version with multiple changes and improvements. To see the full list of features, check out the announcement on our blog.
« Last Edit: December 29, 2021, 09:25:23 am by iToo »
