Author Topic: RailClone Lite/Pro 7.1.2 - plus new railing libraries  (Read 47558 times)
« on: August 08, 2025, 10:56:03 am »
A new RailClone update is available bringing with several useful improvements and fixes, along with new assets to make it easier than ever to detail interior and exterior renders with fully parametric railings. See below for a list of what's new, or read our blog post for a more detailed overview.
RailClone 7.1.2
  • Fixed scale issue for 'Windows' libraries when working with scenes using centimeters.
  • The Offset operator now respects the spline's local coordinate system instead of using the RailClone coordinates. This approach is much more suitable for rotated paths.
  • Improved edge detection when the boundaries of Surface and Spline Areas are coincident.
  • Fixed: Flatten Stepped doesn't work if using an empty Transform node in place of geometry.
  • Fixed: Spline->Transform->Rotation causes a spline flip when rotating exactly 180 degrees.
  • Fixed: Value List cannot use negative values.
  • New library content: iron and wooden balustrades under Architecture > Exterior.
This is the fourth update since the RailClone 7 release. For a glance at other recent changes, please see the following release notes.
RailClone 7.1.1
- Fixed: Library Items using Portable format are not scaled with scene's units.
- Fixed: RCSlice parameters are not scaled with scene's units.
- Fixed material error loading 'Windows' libraries.
RailClone 7.1.0
- Fixed issue of Material operator in Arnold renderer when instancing is enabled.
- Fixed issues with Portable Material libraries.
- Updated 'Windows' library.
RailClone 7.0.9
- Added support of V-Ray 6 in 3DS Max 2026.
- Fixed freeze issue with Segments using modifiers.
- Fixed: items are not properly instanced when using Mirror operator.
- Fixed geometry displacement with some segments using RC Slice.
- Fixed: RC Slice->'Y Default' doesn't work well if 'X Default' is disabled.
- Context menu->Selector dialogs are larger and resizeable.
« Last Edit: August 08, 2025, 03:12:42 pm by Michal Karmazín »
