Author Topic: RailClone Lite/Pro 3.0.9  (Read 13819 times)
« on: September 18, 2017, 10:07:15 am »
A new version of RailClone Lite and Pro is available.
RailClone 3.0.9
- Added "Separate Meshes" option to RailClone tools.
   * When enabled, creates separated meshes for the non-instantiable segments, instead attaching all of them.
- RailClone Tools generates correct meshes (no instances) for segments using Material or UVW operators.
- Fixed crash in Library Browswer using libraries downloaded with old version of Update Manager.
- Fixed: Clipping Area is not aligned correctly when using Generator->Z Offset.
- Fixed crash with some operations after deleting a Note in Style Editor.
- Fixed crash in RailClone Lite loading scenes created with Pro version.
- Fixed rare crash with Clipping areas.
- Fixed behaviour of arrays when using X Rotation and Surfaces (in this case segments are aligned, but not conformed to the Surface).
- Fixed endless loop when using circular references between nodes.
You can find the release notes for previous RailClone versions here.
