Author Topic: RailClone Lite/Pro 2.1.5  (Read 12849 times)
« on: November 01, 2013, 06:59:04 pm »
- Added support for VRay 3.05.03 beta.
- Fixed crash on Style Editor when using Parameter->Constant operators.
- Animated segments are properly updated with Display->Geometry shader is off.
- Animated Parameters and Base Objects are visible in the Track View.
- Fixed: Transform Operator was applying global scale twice.
- New algorithm for no-Bend Segments was not working as intended. Reverted to 2.0.4 version.
RailClone Lite/Pro 2.1.3
Style Editor:
- Style Editor is now integrated within Max. Stay-on-top is not longer needed, all connection issues should be solved.
- Added Selector operator: selects a Segment according to an index.
- Added Transform operator: transform and modify properties a segment (alignment, padding, scale, etc.)
- Added expressions to Arithmetic operator.
- Added contextual creation menu (using right click->Add or dragging links).
- New subtype of Numeric parameter: Boolean (returns 0-1).
- Most of nodes can be turned off (clicking checkbox at right top corner when is selected, or by right click contextual menu). Each node has a specific behaviour when is off.
- Generator->On field is not longer needed and has been removed.
- Alt+Click selects a node and its childrens.
- Added Ctrl+C / Ctrl+V shortcuts for Copy / Paste actions.
- Allowed zoom over 100%. Set zoom limit at Options->Preferences.
- Added Options->Preferences->Rename Segments when Reload (on/off).
- Added Options->Preferences->Show Warning Messages (on/off).
- Exported parameters are highlighted in red color.
- Improved undo/redo.
- Fixed limits of several parameters.
- Fixed: Segments can be connected to exported parameters.
- Delete key doesn't remove items anymore, when used from Style Editor controls.
- Spline node is updated in the Style Editor when assigned from Base Objects and viceversa.
- Spline can be cleared from Style Editor using context menu->Clear.
- Fixed potential crashing issue picking objects from Style Editor.
- Fixed limits of exported parameters.
- Material Operator->From/To parameters can be exported.
New features and changes:
- Added support for VRay 3.0 beta.
- New parameter: Style->Geometry->Simple Y Offset mode.
    RailClone uses a sophisticated algorithm to compute Y Offset paths, but it some cases it would not generate a correct result.
   We have included an alternative simpler mode that could solve these cases. Enable it if you get distorted geometry when using Y Offset.
- Added Adaptive mode for Generator->Rules->Default. Bevels are not allowed on this mode.
- Added Adaptive mode for Generator->Rules->Evenly.
- Added Vertical Top/Bottom for Segment->Stepped mode. It works similar to Flat Top/Bottom for Vertical mode.
- Added A2S Generator->Clipping area->Extend X/Y Size to Area->Expand.
- Improved precision for alignment of segments with Bend off.
- RailClone Tools sets Octane "Movable Proxy" property to the instanced items.
- Display->Render->"VRay/Mental Ray shader" renamed to "Use Geometry Shader"
Fixes:
- Animated Segments are properly updated.
- Fixed Conditional->Y Counter when usign Y Evenly.
- Fixed several geometry issues with Generator->Limit by ID.
- Array Generator using Free mode works correctly with negative Y Size values.
- Randomize Operator works properly with Start/End/Left Side/Right Side.
- Randomize->Percentage is limited to 0-100
- Fixed Y Offset issues with closed splines.
- Generator->Default->Scale handles correctly Composed segments.
- Fixed Y Sequence operator when used with Evenly/Corner
- Fixed bug with no-slice segments and paddings.
- Fixed right menu on Library Browser when there are not items selected.
Library:
- Several presets has been fixed or improved (handrails, ducting)
Registered users of RailClone Pro can download the upgrade from the User Panel. The Lite version is freely available to download in our website.
