Author Topic: Limit by Material ID not working  (Read 161711 times)
« on: December 20, 2013, 01:28:14 pm »
Occasionally when using the Limit By Material ID option of a generator to restrict geometry to a particular section of a spine, it is generated incorrectly. This is often caused by using Adaptive mode, found in the spline’s Interpolation roll-out, which can scramble the material IDs. If this issue occurs, simply turn off adaptive mode to restore the correct behaviour.
