Author Topic: Uninstalling RailClone 2  (Read 145954 times)
« on: March 29, 2013, 02:10:51 pm »
I got several errors after uninstalling RailClone 2, and coming back to version 1.x. Why ?
This error happens because some macros and values are stored in the user's folder, and cannot be removed by the setup program.
If you want to uninstall RailClone 2 to restore RC 1.x, please use the following procedure:
1) Close Max.
2) Uninstall RailClone 2 from the Windows Control Panel->Add or Remove Programs.
3) Remove the registry key HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro\LibraryMacros, or run the attached .reg
4) Delete all files .mcr that use prefix RailClone-RC from the folder
       C:\Users\<user name>\AppData\Local\Autodesk\3dsmax\2013 - 64bit\ENU\usermacros (replace 2013 - 64 with your Max version)
5) Install RailClone 1.x
Note: RC2 uses a new object format. Once converted, it is not possible to come back to version 1. Backup your scenes before editing them with v2.
« Last Edit: June 11, 2013, 09:17:32 pm by iToo »
