Author Topic: I can't get shadows with my trees -  (Read 30922 times)
ron_ADST
« on: September 26, 2010, 12:03:14 pm »
When i try to get shadows to my trees nothing happens.
I put the shadowmaps in the forestmaterials. Now I should link the material to the shadowmaps in my light but in a daylight system there is no shadowsrollout. Do I have to use a different light or is there a different option?
kind regards Ron
Re: I can't get shadows with my trees -
« Reply #1 on: September 26, 2010, 12:27:05 pm »
Are you using Mental Ray ?
If so, it's not needed to use XShadow (or other shadow maps), it's only applicable to the Scanline renderer. Please, try this:
1. Use Forest Material for your materials
2. Assign the light in Forest->Shadows->Raytrace->Light
That's all. You can see a guide to use billboards with different renderers here:
http://www.itoosoft.com/forum/index.php?topic=448.0
If you are rendering 3D trees,  there is not any special requirement. The shadows must work with Forest as any other object in the scene.
ron_ADST
« Reply #2 on: September 26, 2010, 12:45:28 pm »
I'm using Lite on the moment
A daylight system - (MR)
in Forest - Shadows - I checked default
I put the shadow maps to the material
..... use fake shadows has to be uncheked? ....
« Reply #3 on: September 26, 2010, 01:16:36 pm »
You need to set these options in Forest->Shadows:
- Use Fake Shadows - Enabled
- Vertical - Enabled
- Horizontal - Optional, only if you assign a horizontal shadow map in the material
- Raytrace->Light - Pick the daylight sun light
If you are using Forest Material with a Standard material (the recommended combination for MR), it's not necessary to assign a shadow map in the material, Forest uses the opacity map for the shadow.
If you like, post here the scene for checking.
ron_ADST
« Reply #4 on: September 27, 2010, 09:30:04 am »
for stupid people like me (!) - maybe it is better to change the name of the button from none to pick light?
Finaly I understand. Thanks
« Reply #5 on: September 27, 2010, 11:34:05 am »
The 'none' label is set by default in the pick buttons by Max, but i think it could be changed. We'll take a look to it.
Thanks for the suggestion !
