Author Topic: max crashes when rendering forest pack scattered vray proxy with vray next  (Read 23526 times)
poligar
Hi !
crashes constantly on second render when scattered vray proxys
first render goes well , second not even starts .
anyone with same issue ?
Hi, what Forest version do you use ?
There was a similar problem which was fixed in a recent update.
I would suggest you download it again, to be sure you're using the latest version (FP 6.2.1).
poligar
I think it's 6.1.5 , I will check newer version thanks, I cant find that bugfix in release notes , spent whole day struggling that issue tried 100 variations but crashes anyway, something tells it will crash even after update
you try simple setup with vray proxy .
interestin thing is it crashes at second render not at first
« Last Edit: May 05, 2019, 07:37:57 pm by poligar »
gamrin
hi! have you solved your problem? I have the same thing (
3ds max 2020
vray next, update 2 (4.20.00.00001)
Forest Pack Pro 6.2.2
Hi gamrin
Please update to latest ForestPack (6.2.4 at this moment).
And if problem still occurs, please send us Your simplified crashing scene.
