Author Topic: Custom object scaling in the Z direction  (Read 16985 times)
dande
« on: April 29, 2011, 12:48:34 pm »
I have just downloaded Forest Pack lite. Its great. But I have 1 problem. I am using Forest Pack lite to scatter my custom object. Which is a mesh containing a few thousand grass strands. The mesh is 2 metres wide by 100mm high. When I render using mental ray the custom object scales in the Z direction by about 10 times. See image 1. Image 2 shows the original grass mesh which I am using my custom object.
I am distrubuting it using the dense.bmp and I have changed the density units to 10. I am scattering it on editable mesh.
Image 1 shows the rendered image. Image 2 show the original custom object
Re: Custom object scaling in the Z direction
« Reply #1 on: April 29, 2011, 05:45:57 pm »
Try applying a 'Reset XForm' to the mesh before assigning it to Forest. It that doesn't work, please send us a test scene to support@itoosoft.com or post it here.
dande
« Reply #2 on: April 29, 2011, 11:16:36 pm »
Thank you Carlos. That solved my problem. It's a great program and solves a number of problems I've been having for a while.
I will definitely be purchasing the pro version
Thank you
