Author Topic: Forest LOD and XRef Object workflow  (Read 27121 times)
s.large
« on: October 15, 2020, 06:09:25 pm »
Hey guys, just curious about how to go about setting up XRef Objects with Forest LOD's.
A) Do I put the Forest LOD object in the same file as my scatter objects and then use those in my master file via XRef Object
OR
B) Do I set up the LOD source geometry in one file, XRef Object those into my master file and create the Forest LOD object in the master file?
Let me know if you want me to clarify further.
Cheers
Re: Forest LOD and XRef Object workflow
« Reply #1 on: October 16, 2020, 08:58:16 am »
I would go with B from these two options, as You would lose LOD control if LOD object is xrefed.
