Author Topic: Forest Pack Lite – Objects not rendering in final output?  (Read 35226 times)
evelynwang
Hi everyone,
I’ve just started using Forest Pack Lite with 3ds Max 2024, and I’m running into an issue where the scattered objects (trees, grass, etc.) show up perfectly in the viewport, but when I render using V-Ray, they don’t appear at all in the final render.
I’ve double-checked the Forest Pack settings and the geometry is all properly linked. Could it be a limitation of the Lite version, or am I missing a setting?
Any help would be greatly appreciated!
Re: Forest Pack Lite – Objects not rendering in final output?
« Reply #1 on: July 28, 2025, 08:32:10 am »
I'm sorry to hear you're experiencing trouble with it. Are you able to reproduce the issue when rendering locally, via network rendering, or using distributed rendering? Do you see any error or warning messages? You can check the Forest Stats window under the General rollout — it should provide more insight into what might be causing the problem.
