Author Topic: Does Forest Pro work with render-to-texture render?  (Read 9074 times)
kirk
« on: July 25, 2012, 07:27:58 pm »
I tried Lite in Max 2008 and it doesn't.  You just cant pick the forest object in projection modifier. Is there any workaround?
Re: Does Forest Pro work with render-to-texture render?
« Reply #1 on: July 25, 2012, 10:44:34 pm »
It seems render-to-texure requires a mesh object to work. Please try setting Display->Viewport to "Mesh", and perhaps Display->Render to "Mesh" is required as well.
But probably it will work only with simple distributions, because a full UVW unwrap of a complex Forest object would be huge.
