Author Topic: Black trees in MAX 2008  (Read 77171 times)
Nir Sullam
« on: May 06, 2008, 10:12:52 pm »
Although I see the transparency as it should ie, tree shape is OK but the color map is dead black.
Mental Ray is used .
NIR
Re: Black trees in MAX 2008
« Reply #1 on: May 07, 2008, 04:21:49 pm »
Please see the sticky post "Common Problems: Using Forest with Sun & Sky solutions (Mental Ray)" on this same board. This info was already in a post on the Forest Pro board, but i just copied it here as well.
It you don't solve the problem, please post here the configuration of Mental Ray that you are using: Light's properties, Exposure control and so.
