Author Topic: Can't scatter this Object  (Read 10138 times)
KeRo
« on: September 29, 2013, 10:11:16 am »
Hi at all,
I just started to work with forestpack. At simple scenes everything works fine.
But if I try to scatter a more complex editable poly it doesn't work :/
Here is my scene:
http://www.mherbig.de/1.zip
Hope you guys can help me :)
Re: Can't scatter this Object
« Reply #1 on: September 29, 2013, 10:43:13 am »
Be sure the normals of the surface are pointing up. In this case, they are inverted.
Just apply a "Normal" modifier to the terrain, and reload it in Forest (click the "Refesh" button in the Surface rollout).
KeRo
« Reply #2 on: September 29, 2013, 11:01:41 am »
Thank you, now it works!
I tried that before to flip all polygons by the "flip" command in the editable poly rollout, that doesn't work.
But the Normal modifier works :)
