Author Topic: can you delete the original trees in a scene  (Read 9160 times)
Brit
« on: September 08, 2012, 08:12:24 pm »
just working through the barn tutorial (up to video 3), very good
Wondered if it is possible to delete the scatter objects trees after creating the forest, or will that muck up the scene?
Cheers
Re: can you delete the original trees in a scene
« Reply #1 on: September 08, 2012, 09:12:31 pm »
No, it's not possible to delete them. Forest keeps a reference direct to the objects.
Even the plants imported from the Library Browser, are stored in the scene (in this case, in the hidden layer "forest_templates").
Brit
« Reply #2 on: September 11, 2012, 12:48:13 pm »
Thanks.
Another question:-
if i update/change the materials on the original scatter object trees , will it update the forest or do i have reload the trees?
« Reply #3 on: September 11, 2012, 02:27:14 pm »
Forest doesn't use directly the material assigned to the oject, but the material defined in Geometry->Geometry List->Material.
Since this parameter is updated when a Custom Object is selected, you should reassign the object, or drag the new material to the slot.
We have plans to add a "Reload all" button to the geometry list, to simplify this task.
