Author Topic: File dense.bmp could not be found  (Read 12608 times)
dmkpankov
« on: March 17, 2015, 04:13:12 pm »
Hello colleagues!
There is some error, when I'm trying to create grass.
Here is screenshot of error.
Please reply, if anyone knows how to solve this problem.
Re: File dense.bmp could not be found
« Reply #1 on: March 17, 2015, 05:06:56 pm »
That file (dense.bmp) is one of built-in Distribution Maps by default located at C:\Program Files (x86)\Itoo Software\Forest Pack Pro\distmaps\images.
Actually, to prevent these problems, Forest Pack is double checking if all needed paths are listed there and offers you an automatic addition (see attached screenshot). Could be, you've skipped that step.
Anyway, it can be easily fixed by adding the path to these assets under the 3ds Max's configuration Customize - Configure User Paths - External Files stored in 3dsmax.ini. The ini file is located by default here:
C:\Documents and Settings\<username>\Local Settings\Application Data\Autodesk\3dsmax\<max version>\enu\3dsmax.ini
Hope that helps.
Kind regards,
dmkpankov
« Reply #2 on: March 17, 2015, 05:21:34 pm »
Thanks, it works for me  ;) 8)
