Author Topic: lots of grass  (Read 66074 times)
mumle
lots of grass
« on: June 11, 2009, 03:55:35 pm »
Hi, im trying to make a scene with a huge amount of grass, but when i make the distrubution-map smaller everything vanishes and it says i have to make it larger... So what are the best way cover a huge surface with grass? And there something special I can do to optimize it?
Re: lots of grass
« Reply #1 on: June 11, 2009, 05:18:05 pm »
There are a couple of parameters that limit the maximum number of items (Display rollout) and maximum density (Distribution rollout). If Forest shows a 'F' icon and doesn't display any items, use the "View Stats" windows (General rollout) to check what is the problem and increase these parameters.
However, there is a good trick to create a grassy field without using a huge number of instances:
- Using Forest, create a grass patch with some hundreds of blades
- In Display rollout, Change "Mode" parameter from "Automatic" to "Meshes"
- Create a new Forest object, taking the grass patch as Custom Object. On this, set Mode to "Automatic" (default value)
... and you get a hierarchy of two Forest objects working together. Adjust parameters to get the desired result.  ;)
For very dense distributions, we usually use a "Full" distribution map, applying a Random Traslation of 20% to avoid the grid effect.
mumle
Re: lots of grass
« Reply #2 on: June 11, 2009, 09:41:27 pm »
Thanks, will look at it tomorrow when im back at work. Loving your plugin  :)
mumle
Re: lots of grass
« Reply #3 on: June 12, 2009, 03:02:57 pm »
It makes it easier to distribute it, but at work we have the pro version and by doing it that way its hard to make it follow a terrain. And as it is now, the most common problem i'm having with grass is the computer crashing when "transforming vertices". We are using vray.
Re: lots of grass
« Reply #4 on: June 12, 2009, 05:56:44 pm »
Perhaps your grass patch is too large to follow the terrain... have you enabled "Align to Normals" in Surface options ?
No idea about the crashing problem, i would need to check the scene.
I just created a grass test scene, you can use it as help. It uses two linked Forest Pro objects + terrain + VRay, requires Max 2009.
mumle
Re: lots of grass
« Reply #5 on: June 14, 2009, 10:37:16 am »
so its easier for the memory to use two FP-systems than make the first patch into a single mesh and just use one system?
Re: lots of grass
« Reply #6 on: June 14, 2009, 11:02:04 am »
Not really, because VRay converts it to mesh before rendering. But this way you can modify the patch easily, without re-creating the mesh. Futhermore, would be possible to animate the Forest parameters to create some fancy effect (density, scale, rotation, tint....)
mumle
Re: lots of grass
« Reply #7 on: June 14, 2009, 01:12:36 pm »
fair enough, I'm just mumle's liver trying to understand himself :)
Re: lots of grass
« Reply #8 on: September 05, 2009, 11:16:08 am »
I've uploaded a test scene using Mental Ray and Forest LIte (requires Max 2009).  It needs some material and lights adjustments, but could be used as base to work.
