Author Topic: Effects Library empty  (Read 22318 times)
archimi
« on: March 20, 2019, 12:48:52 pm »
I just installed Forest Pack Lite and I find this software great for creating carpets and more.
Before moving to the pro version I would like to test the effects, but strangely the effects library is empty.
Is this normal or is it a problem with the installation ?
Re: Effects Library empty
« Reply #1 on: March 20, 2019, 02:35:26 pm »
Sorry to hear, you're facing these problems. Would you mind to provide us the value of the following system registry key (by using regedit.exe)?
Computer\HKEY_CURRENT_USER\Software\Itoo Software\Forest Pack Lite\EffectsDir
Meanwhile, copying files from
C:\Users\<yourUsername>\AppData\Local\Itoo Software\Forest Pack Lite\effects
to
C:\Users\<yourUsername>\OneDrive\Documents\Forest Pack\effects (to User's Path) should help.
Thanks in advance for any further comments on this issue you can share with us.
Best regadrs,
archimi
« Reply #2 on: March 20, 2019, 03:08:13 pm »
Thank you for your reply.
I found where the problem comes from: there are two directories created in C:\Users\<yourUsername>\AppData\Local\Itoo Software\
the first is "Forest Pack Lite"
and the second is "ForestPack Lite"
I copied the Effects files from first to second and it works now.
Best regards
