Author Topic: Transform scale pivot  (Read 10110 times)
ibanks
« on: April 05, 2013, 05:33:41 pm »
Would it be possible to amend forest pack 'scale' in the 'transform' tab, so that when randomizing the scale in the z direction it scales from the pivot and not from the center of the object. (ie, the base of all my trees stay planted on the ground and not some above and some below.
iain
Re: Transform scale pivot
« Reply #1 on: April 05, 2013, 07:15:24 pm »
Now it should scale from the Pivot (see attached sample). Are you using stock trees or custom models ?
Please, try applying Utilities->Reset XForm to you tree model. That would solve the problem.
