Author Topic: Facing problem converting proxy into into mesh  (Read 10262 times)
samp
« on: January 20, 2016, 12:01:46 pm »
I created a environment in 3ds max with forest pack plugin (i used vray proxy model) and in the final stage trying to convert forest plantation (proxy mesh) into mesh, i am facing a problem - the mesh is not properly visible. I have attached the image below, (in right side image is vray proxy and left side is converted forest mesh). Also my file size is increasing. kindly a give solution.
Re: Facing problem converting proxy into into mesh
« Reply #1 on: January 20, 2016, 01:39:26 pm »
Forest Pack doesn't convert automatically any used proxies (VRayProxy / CoronaProxy / mr Proxy objects) into meshes.
An option would be to Import as mesh your VRayProxy object and use that one.
Let me mention, that the Forest Pack Pro allows you export your scattered geometry as instances (in this case instanced proxies). Please feel free to check more details regarding this feature in our on-line reference guide.
Full list of locked features for the Lite version can be found in our Forest Pack's Feature list.
Hope that helps.
